clutch slave cylinder replacement
Thothie
I noticed the rubber on my clutch slave cylinder is leaking. Is there a rebuild kit for this? If so, what part number? I took out the clutch dampening and connect the mastercylinder line to SS directly to the slave. The effect is not there due to I believe the leaking slave cylinder. Please help.
GTR-33
Replace the cylinder and bleed the system. Clutch cylinders aren't too expensive, around 40USD... I believe Nissan does make a rebuild kit thats around 10USD too though.. I don't know how well that will work though.
dareo
Car: 1993 Q45, 1989 240sx
mine just went out too, i got a new slave cylinder for 20 bucks at autozone. It doesnt look like its the highest quality piece of equipment in the world though.
TrunkMonkey
Car: 2000 Lincoln Navigator
GTR-33 wrote:I believe Nissan does make a rebuild kit thats around 10USD too though.. I don't know how well that will work though.
the rebuild kit works beautifully. it takes maybe ten extra minutes to remove, rebuild and reinstall vs. replacing altogether.
-demetrius
TrunkMonkey
dareo wrote:mine just went out too, i got a new slave cylinder for 20 bucks at autozone. It doesnt look like its the highest quality piece of equipment in the world though.
i've heard horror stories...
-demetrius
dareo
the install and bleeding of my slave cylinder was a success, even though i knew nothing about how to do it.
I used the worlds cheapest slave cylinder ever, i dont know how long it will last.
Good thing i plan to swap this spring or summer. Buy a good one if you plan to keep it for more than a few months.
GTR-33
Like I said the OEM Nissan unit is 40 bucks. HT and P2M have the Nismo unit for 150. They both also have the Nismo clutch fork pivot.
