Truck »
https://forums.nicoclub.com/truck-u68614.html
Thu Apr 01, 2010 6:39 am
The original poster didn't fully explain everything, and when he copied the FSM, he left an important detail out.
Lets clear this up.
Bleeding ProcedureBleed air according to the following procedure.Clutch dampener --> Clutch Operating Cylinder (slave cylinder)1. Top up reservoir with recommended brake fluid.2. Connect a transparent vinyl tube to air bleeder valve.3. Fully depress clutch pedal several times.4. With clutch pedal depressed, open bleeder valve to releaseair.5. Close bleeder valve.6. Repeat steps 3 through 5 above until brake fluid flows fromair bleeder valve without air bubbles.
Yes, use brake fluid. Dot 3 is the recommended spec. If you are unsure what or where the Clutch Dampener is, it's location is between the Clutch master, and the clutch slave. It is a Box with two hard lines, one to the master cylinder, one to the slave, and also a bleeder valve.
There are links to the FSM for the 89 model year (on this website) with some pictures of these parts, if you need more clarification.
