Hey guys, I need some help because the google machine is turning up nothing.
I just mated my VQ trans to my 2JZ and I don't have the banjo bolt that came with the slave cylinder. Can someone help me with what size banjo fitting and banjo bolt size I need? I need to get a custom line from 1/8"npt fitting at the master cylinder to whatever size banjo that is. I measured the bolt diameter of 8.7x mm so I assume it's M8 x something but none of the M8 bolts I have would thread in so I can't determine pitch.
Much appreciated!
