I bought my Z a couple of months ago, and dealt with it only running on 5 cylinders until a couple of weeks ago... first off, holy poop, what a difference!
I did a price comparison between the two, and wound up with about a $200 difference. Here's what I have in each cart:
- Street clutch kit (mild performance/sport street)
- Flywheel
- MT pilot bushing
- Throw out bearing
- Alignment tool
- Rear main seal
- MT input shaft seal
- MT rear seal
- Shifter bushings
- SS clutch line
Specialty Z comes in higher - granted I've yet to call them about the order, this is just from the online prices. That being said, most of the gripes I've heard about Z1 have to deal with order accuracy/timing issues. Aside from that, are any of you aware of quality/reliability issues with the Z1 clutch kit? I'm running factory boost right now and the only upgrade I plan to make in that regard is to up the boost to 15psi... eventually. I have no plans on changing turbos.
Thanks in advance - any advice is greatly appreciated... as well as any other recommendations for "while you're in there" type things.
