gtune4 »
https://forums.nicoclub.com/gtune4-u9024.html
Fri Dec 16, 2005 7:52 pm
Well this will be #3
i was wondering by way of opininon or if anyone has done this.
i am going to be doing my clutch for the third time. first time the gear oil leaked all over my act clutch and it burned out in 22K.
next i used an 89 maxima clutch beacuse i was broke, it lasted about 24K!!
now i saved my old clutch and was wondering, if i simply buy a replacement act street/strip disk,
should i reuse my old pressure plate from the act clutch?
it was working well when it came out, the disk had been clearly destroyed/worn down to the rivits, but they hadn't scored the pressure plate. i would really like to save money on this and replace my stock motor mounts instead of buying another clutch kit!?!
let me know what you think or if you have done this before!
ps. the max clutch isnt too bad for 120bucks at local store as a cheap fix, i wouldn't totaly rely on it, just if you cant afford anything else it will get you moving again (this is my only car). i just give my car a hard time, love tha boost!
pps. if this should be posted somewhere else sorry, i couldnt find a drivetrain section?
