weslvmaG37 wrote:
If I don't burn the clutch everything is normal. I'm sorry i wasn't so specific before.
If you don't slip the clutch it won't overheat causing either a small layer of gas or clutch material depending on the amount of wear already on the clutch. Clutch problems with the 08's are very minimal since the inception of the concentric slave.
You need to take into account the way that a clutch works when friction and pressure bind the two main components together, when you alter the friction coefficient by not applying that correct amount of apply pressure the clutch disc does not contact the flywheel and excessive heat is generated very quickly. Remember the dual mass flywheel is not serviceable and in some cases is not warrantable.
