Clutch question
Brandon1605
Car: 1989 Nissan 240sx (S13)
Is the clutch for the DOHC and the SOHC interchangeable? Im about to half to put a new clutch in mine and I want to upgrade to something that can take a little more abuse. A motor swap is a pretty good ways away, so its not a waste for those that are thinking that. Also, whats best? I personally think ACT, but I have little experience actually using one in a 240.
DanThaMan
Car: 1993 240sx
yup same thing, I'm partial to my SPEC stage 2+....takes abuse and doesn't misbehave on the street
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
ACT or Exedy stage one if you are staying stock for a bit. I personally had a horrible experience with spec. DOHC & SOHC clutch should be the same.
LoserCard
Car: Forest Green 1993 240SX SE Fastback
I like Exedy Stage 1, although I might upgrade to stage 2 for stronger engagement.
Shadow Drifter
Car: 1990 240sx
DanThaMan wrote:yup same thing, I'm partial to my SPEC stage 2+....takes abuse and doesn't misbehave on the street
Excatly what he said
