clutch question
kazuma
Okay so I made the mistake of buying a used clutch last year and at first it worked fine but this year when I tried to drive the car after 15-20 minutes of driving I can rev but the car wont move. So I came home and did the old 4th gear test. I stopped after a drive, put the car in 4th and let out the clutch to find out the car stays on and doesnt stall! so I knew my clutch was toast.
anyways I took the clutch out and this is how it looks.
here is the pressure plate(sorry I suck at taking pics :D)
now I believe and the people I've shown this to believe the disc is done but the pressure plate is reusable and I want more opinions on the matter.
by the way this is a nismo 350z clutch disc and pressure plate. its being used on a ka-t with a rb20 flywheel.
r3v_v3ng3
Car: 91 fastback ka-t
reuse the pressure plate.... why? just get a new set so you won't have a problem anymore. besides the pp looks burnt
kazuma
ya the pressure plate has some hot spots on it because of the clutch disc(the disc is much worse! but even a tech I showed it to said the PP looks fine less the hot spots.
kazuma
I took the safe route and ordered another clutch kit!
I was looking inside the transmission today and I found out there is a leak at the plate behind the input shaft! I think what happened is the transmission leaked all over my clutch/pressure plate!
Here are the pics.
they are upside down. this is actually at the bottom of the bellhousing where it meets the engine hence why I thought it was comin from the motor.
I wonder how easy it would be to replace that gasket?
neverlift
just take a look in the fsm and see if anything is gonna fall out when you take it off... if it looks cool go for it.
kazuma
neverlift wrote:just take a look in the fsm and see if anything is gonna fall out when you take it off... if it looks cool go for it.
did what you said . looks like there is a gasket and a seal behind there. put the order for both, will have them tomorrow then its transmission rebuilding time!
motoman399
Car: 98' wrecked (RHD coming soon) 240
the only thing that will fall off is a shim. but its no big deal.
oh and yes there is a seal on the shaft and a gasket on the plate to the bell housing
