Clutch question
ziggyzow
Car: 240sx
I have clutch fluid comin out my clutch pedal? Any ideas?
gumby74
Chances are better than good that your master cylinder is toast.Fortunately they are not that expensive, about $28 with a small bottle of brake fluid.
leper421
Car: Current: 2011 370z
Previous: 2003 350z, 1991 240sx
gumby74 wrote:Chances are better than good that your master cylinder is toast.Fortunately they are not that expensive, about $28 with a small bottle of brake fluid.
Agreed... If you are seeing fluid leaking inside the firewall where the clutch pushrod goes into the master cylinder, then it needs to be replaced. I've done it twice on my 240, and I have helped two friends replace the clutch master on their 240s.
