JETPILOT »
https://forums.nicoclub.com/jetpilot-u100465.html
Sat Jul 05, 2008 7:55 am
Where is the squeeking comming from? The pedal or the actual clutch assembly? if it's comming from the pedal likely it's your master cylinder. if your clutch is softer than usual it may be that your master cylinder needs to be bled or you have developed a leak. Check the clutch fluid level, check the line and slave cylinder for leaks.
If you actual clutch were on it's way out you couldn't drive the car. The clutch would slip (rise in rpm and the car doesn't go anywhere).
