clutch question
oneksS13
Car: workin on mine and buddies cars, hangin out, goin fast
ok so i bought a ca from a guy a while back and got a new clutch with it but he said something about it being for a ka24de and that i would have to grind on the bell housing to fit (havent even looked at bolt pattern for flywheel yet) its a brand new act set and i only paid 1300 for everything (uncut harness, radiator, maf,and a turbo with nearly 3mm of shaft play!) any help would be great also looking for an intercooler on the cheap let me know
slw240sx
Car: 1990 Ca18det 240sx Hatch
what yah need help with?
oneksS13
i have a clutch for a ka but i need to know what machining i need to do to fit my ca
Doogz
Car: '89 240sx coupe
I didn't think you needed to do any modifications to the bellhousing. I thought you just needed to move the bolt holes so it would line up with the flywheel. I'm not 100% sure on that but im sure someone else will know exactly what needs to be done.
NeedCAforS13
Car: CA swapped S13 coupe
pull the pin out of the flywheel that doesn't fit right...use some vice grips and pull it out. it will work fine on the remaining 2 pins:D
Sean
CA18Fastback
so i can use a KA clutch on my CA? it would only be until i got a better clutch.
-Ian
oneksS13
cool thanks guys ill try that
alfred183
NeedCAforS13 wrote:pull the pin out of the flywheel that doesn't fit right...use some vice grips and pull it out. it will work fine on the remaining 2 pins:D
Sean
Does this hold well?? I guess a Nissan tech would know...
NeedCAforS13
the pins are really only for alignment...the bolt holes still line up(and those are what really hold the pressure plate on)...as far as I know it works seeing as thats what Paul used on his ca19det ;)
Sean
Oneor1
Car: cars, music, hockey
so what about a CA Pressure plate w/ a KA clutch?? will that work or do you need to use both KA presure plate and clutch?
NeedCAforS13
should work fine...compare the ka disk to the ca disk to make sure...
Sean
Oneor1
hmmm....my CA one is a triangle and my KA one is a normal one...... not sure if that'll work
