Quach »
https://forums.nicoclub.com/quach-u21454.html
Thu Jul 14, 2005 11:20 am
i recently purchased a new "drift clutch" from illegal garage in san jose, ca. (if you havnt heard of it, its because the owner max is the only one who makes and sells them). anyways, i got the new clutch in, and i replaced the master cylinder and bled the system. i have my clutch dampener removed and adjusted the pedal to the maximum height (to get the maximum stroke from the MC piston) . but since ive had the clutch installed, getting the shifter into gears is alot harder, like the clutch might not be fully disengaged. ive never had an aftermarket clutch before, so i wouldnt know if this was normal or not. im worried that im causing premature wear on the clutch by driving it more. the clutch pedal catches pretty much right off the floor too... ive bled the system over and over and i know there is no air in it, are there any suggestions? maybe a slave/MC upgrade? or SS clutch line?
