Clutch Question??
Silvia14SE
Car: 1972 260z 1995 240sx se 1998 maxima
will any clutch and flywheel work both with the ka and the sr trans? if so any recomendations?
ex: act clutch and fidanza fly from a ka on the sr? or vice versa?
Silvia14SE
can anyone answer this question
Silvia14SE
no one could answer this question?
nonchalant rage
Car: s12
yes and no, the clutch and flywheel are dependent on the engine. the sr20 is a 8 bolt flywheel with a 240mm diameter. ka's have a 6 bolt with 225mm diameter. you have to use the clutch for your engine. oh, and the sr20de is 215mm, thats also different. i believe the maxima clutches will fit an sr20, though.
