clutch pull to push conversion
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
well i have heard rumors that a kit exsists to covert a pull style clutch system to a push style slutch system...i have utilized the search button but i have had little luck...so now i am posting up...i have heard that HKS makes a conversion kit but i have yet to find any serious dirt on this..if anyone knows of any info reguarding this many thanks would come your way
Mark
gawdzilla
Car: none
i posted some info on this a while ago. i think there are two threads or so? you can use oem parts. everything has a usdm cross reference except for the front cover and the slave cylinder if i remember right. thread here zerothread?id=149326
kjlindgr
Are you using a GTR transmission for something? If I recall, all RWD transmissions that came on the RB's were push style right from the factory. Only the GTR's had pull style in late R32 style and newer.
I think it's OS Giken that makes the kit.
S14-NEO
kjlindgr wrote:Are you using a GTR transmission for something? If I recall, all RWD transmissions that came on the RB's were push style right from the factory. Only the GTR's had pull style in late R32 style and newer.
sorry bro but your incorrect..this is a R34 GTT NEO not an AWD...it most definately is a pull style
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
I second that, i have seen this transmission and i helped pull it off this is a PULL not a PUSH ...
S14-NEO
gawdzilla wrote:i posted some info on this a while ago. i think there are two threads or so? you can use oem parts. everything has a usdm cross reference except for the front cover and the slave cylinder if i remember right. thread here zerothread?id=149326
thank you ..can you give me some places where i can source the non USDM parts ill need to make the conversion possible..could i use Z32 parts prehaps?
gawdzilla
Car: none
those p/ns in the thread are valid usdm p/ns. everything except the slave and the front cover. give them to a nissan dealer or punch them in online and you should be able to order them.
EDIT sorry thought you said the usdm parts. the non-usdm parts, i got a nismo slave cylinder so most aftmkt places can get it for the rb25. the front cover i believe i got from rbmotoring, they can order it. takes about 4 weeks though think it was around $35.
kouki-gymkhana
Car: 1993 Nissan 240SX (only 90,000 mi!)
There is a conversion kit made by either HKS or OS Giken (IIRC) to convert it from pull to push type. I have seen the kit advertised on ebay in the rhdjapan online store. If it's not currently listed, you can e-mail them to check availability. If I were you, I'd just put my penny down and pick up a used twin plate from ebay and rebuild it. There's at least 2 auctions going on right now, I believe.
kjlindgr
MeanGreenS13 wrote:I second that, i have seen this transmission and i helped pull it off this is a PULL not a PUSH ...
My bad then. I've only seen ECNR32 and 33 transmissions. No idea they changed them from push to pull. Learn things everyday.
noodl35
There is a kit on http://www.nengun.com/catalogue/product/144 to convert from push to pull but it wont work for you. I'm sure if you ask this company they can get it for you. They are pretty cheap as well.
noodl35
I've seen many pull clutches on ebay. THeres one right now for a nismo gmax pull clutch as well as a hks twin disk pull clutch. THey are used but rhdjapan offers rebuild disks.
gawdzilla
Car: none
kjlindgr wrote:My bad then. I've only seen ECNR32 and 33 transmissions. No idea they changed them from push to pull. Learn things everyday.
yea... r32 (late model on) rb26 and r34 rb25det are pull.
noodl35 wrote:There is a kit on http://www.nengun.com/catalogue/product/144 to convert from push to pull but it wont work for you. I'm sure if you ask this company they can get it for you. They are pretty cheap as well.
yup, those are the parts you need. if you get all oem stuff you'll save about $75 vs. that kit. most likely all of that stuff in the kit is oem except for the stainless looking line.
S14-NEO
yeah i spoke to Danny at RB motoring in reguards to converting to the push style clutch and he advised against it actually..he says the pull style is a far superior design and works much better with less slippage for higher hp cars...which is my main goal..i am looking for 600whp, and if i were to purchase the parts to covert it it would prob be more expensive int he long run to convert it as well as purchasing the correct push style clutch rather that staying with the original pull style and getting a Exedy pull style twin disc.
