SloMoe wrote:I must be missing something, whats so funny? Anyway, back to actually helping you with your problem. Is it only when the trans is in neutral that it makes the noise, or is it when shifting from neutral to the next gear? If its from neutral to upshift, then synchros maybe? Does it do it when downshifting?
ISB is the input shaft bearingits not the syncros, i will be completley in gear, and off the clutch and the noise is still there for a very short amount of time. why isnt it the syncros? becuase its not possible for a transmission to go from 100% perfect shifting and within 500 miles go to every syncro being bad. the syncros only work for a very short amount of time, this sound happens well after the syncros have done their job. also, i already said it only happens on an upshift. not down.
Modified by Kamin at 3:24 PM 9/14/2004
