jaredta1a »
https://forums.nicoclub.com/jaredta1a-u174207.html
Sun Dec 12, 2010 4:44 pm
First try bleeding your clutch slave cylinder (the unit on the bell housing of the transmission) If that doesn't work, From my experience the slave cylinder typically fails first..... They gum up with sludge if they are not physically leaking, you can use a brake hose clamping tool on the rubber clutch line and further diagnose your clutch master cylinder seal (but in some rare cases that can damage the hose, I have never damaged one even using needle nose vise grips)
