Clutch problems?
Two Fowty
Car: 1990 240sx hatch, 1989 240sx hatch
My clutch is super hard to get into gear, and it grinds alot when it does. My pedal feels super loose, and i only feel resistance, when pressing it, when its nearly to the floor. I'm just assuming I need to adjust it , right? Or is there a bigger problem here. This happened several weeks ago; all my fluid leaked out while driving. I thought I fixed it, but then it started messing up how it is now.
And just as clarification, to fix it, I adjust the pedal stopper and withdrawl lever, right?
Thanks for your help.
dmck
you cannot adjust your clutch pedal it is hydraulic it is just like your brakes they are hydraulic no adjustment you can however adjust where the clutch engages further down or more out.....it sounds like it is your slave or master cylinder leaking around the seals or the line itself is leaking
DMan II-40
Car: 1995 240SX SE
Maybe their is air in the system?
