YNOS_ES14 »
https://forums.nicoclub.com/ynos-es14-u12173.html
Mon Dec 22, 2003 4:52 pm
Check the connecting arm from the Clutch master Cylinder. It is that arm that connects your Clutch Pedal to the Clutch Master Cylinder through your firewall. It is in the shape of a tuning fork. One side may have snapped. Very easy to replace. You will have to purchase a new Clutch Master Cyliner if this is the case. If you do, you will need new Brake fuid to go along with it. If you have any questions, IM me.
