ammons_eli wrote:yes i meant clutch pressure i didnt know there was a second bleedout valve besides the one on the slave cylinder and the flywheels teeth still look good
I wasn't talking bout the teeth, by the way. The flywheel is like a big brake rotor and the clutch is like a big brake pad. Just like rotors, flywheels will lose thickness over time or crack from heat and stress. Whenever you do a clutch job, you need to inspect, resurface, or replace the flywheel. For peace of mind.
Yeah, more info on what you did will help.
http://www.youtube.com/watch?v...edded
Modified by moyea at 7:53 PM 7/14/2009
