ken240sx »
https://forums.nicoclub.com/ken240sx-u27409.html
Thu Apr 10, 2008 5:48 pm
ha, well it's a different part number....which means there is probably some differences, but if you have one laying around..why not try to install it. I'm almost sure it should work, seeing as how so many other things are interchangeable. Hell, you can bolt a 300zx master cylinder and front calipers right up, why not an sohc slave cylinder? try it and tell us if it works out, if one's cheaper than the other then i'll end up buying the cheaper one if it works whenever i need to replace mine.
