clutch problems!
blacktop sr20kid
Car: 1990 240sx
put my engine back in.
i have an excedy stage 1.a lightweight Clutch Master flywheel...
And my car won't move!! runs good. but the clutch won't engage???
is it the lines or the clutch? or idk?
any help would be much appreciatedthanx!!
scottydog
Car: 1992 240sx
Gotta be more specific. Will it go into gear? If in gear and you release the clutch pedal it goes nowhere?
redhat-z
Try moving the clutch fork by hand. If you can, pull it all backapart.
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
does the transmission push into gear? does the clutch pedal feel like it is pushing the pressure plate? help us help you.
uberkillerz240
Car: 1991 240sx sr20det redtop w/ bpu
With that great info, there is little help we can give. could be that u didn't bleed the clutch.....or u have a bad slave cylinder....etc etc
blacktop sr20kid
Car: 1990 240sx
yes it goes into all gears.but it doesn't move at all!
the clutch feels pretty soft.
and yes i bled the clutch....
denas240
Car: 1990 240sx
just take it apart again and check the throw out bearing. you probably didnt put it on right
blacktop sr20kid
Car: 1990 240sx
denas240 wrote:just take it apart again and check the throw out bearing. you probably didnt put it on right
how can you put a throughout bearing on wrong???
And is it easier to pull the engine or drop the transmission???cause i pulled the motor last time?
scottydog
Car: 1992 240sx
The throwout bearing can be put in backwards, or the bearing lever can be messed up. If you reach down at the slave cylinder you can take the rubber cover off the lever and peak inside. See if the lever looks correct, with it's retaining clip. Can the lever be moved by hand? If it's loose you need to pull the transmission and redo it.
