clutch problems
kstowers
Car: 2007 Nissan Versa Sedan S
I have an 07 Versa Sedan S, 6 speed, pwr pkg.... While waiting at a red light, I noticed that I lost "pressure" with the clutch pedal. When I lifted my foot, the pedal didn't come back up. Towed for service, they replaced the clutch (bad seal). Now its even worse. Clutch engaging 1/4 inch from floor. Back to service.
Has anyone else had problems? This is a fantastic car. Averaging 35 to near 40 mpg!!!
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
If it were an old style cable clutch, I would say it's just out of adjustment.
But it's a self-adjusting hydraulic clutch... so I'd be worried that if you had a bad clutch seal, you might also have a bad clutch master cylinder.
Hydraulic clutches are great in that they last longer than cable clutches, and self-adjust... but when they break, they CAN be more complex failures.
hdtom1
Car: 07 versa sl, 6spd
you wouldn't happen to see fliud leeking anywhere would you?
BBISHOPPCM
Car: '06 Nissan Murano S AWD w/ Convenience Pkg
Sounds to me like they did not properly bleed the hydraulics. Take that baby back and ask for a "bubble chaser!"
kstowers
No, that's the crazy part. The service manager said that fluid collected on the clutch so they replaced the cylinder, cover assy and the disc assy.
kstowers
So a hydraulic clutch needs to be bled like a brake? I've never owned a vehicle with a hydraulic clutch. My trade in for the Versa was a 5-speed 97 Mercury Tracer and I never had a problem with the clutch in it. I've never owned an vehicle with an automatic trans either, but I'm wondering if I shouldn't have purchased an automatic Versa. (but I love that little 6 speed-ha)
Ever Victorious
'73 AMC Hornet
Actually, you would be the first case I've heard of with an actual failed clutch on a new Versa. There were a couple of us who had clutch slippage early on, but that was caused by a mis-adjusted ASCD switch on the SL model (part of the cruise system that taps into the clutch hydraulics).
Yeah, a hydraulic clutch works very similarly to a brake system. And air in the system will REALLY screw with its ability to operate.
