Alteus »
https://forums.nicoclub.com/alteus-u48593.html
Sun Mar 11, 2007 7:58 am
So on my way home last night, my clutch pedal just kind of took a dump on me. That is, it's now even with the dead pedal, with a very short pedal travel. The car won't go into gear from a stop when it's on. It shifts fine, however. So the only way I can get the car to go anywhere is to put it in first while it's off, then start it.
So my question is, do you think this is a straight up clutch problem, or could it be the slave / master cylinder? Is there any way to diagnose it myself? I checked the reservoir and it's full, so I know it's not a leaking fluid issue. If it is the clutch, what do you guys recommend I buy? This is a daily driver that will see some occasional track use, so I don't want to get anything overkill, but I do want something better than OEM. I'm looking at the Centerforce clutches.
