Clutch Problems.
littledoomy
Ok, I've searched for this and found out all I need to know except for one thing. My problem is that after I put in a new clutch it is fine for a bit, but then goes bad quickly. I read that you can get rid of the box between the master and slave, and that is supposed to fix the problem. My question is, are there any negative side effects that could happen from removing this box. I know I would just remove it and run the line straight to the slave. Please let me know if this really is a good idea. Thanks!!
bj180sx
Car: cars
Only neg affect is a little vibration in the pedal. All that box does is soften the pedal alittle.
littledoomy
Thanks a lot for your help!
