Clutch problems???
Adam_11
Car: 91 240sx
ok so on my way to class last week my clutch pedal went dead... i had no pressure and the clutch wouldn't disengage and i couldn't shift. So i took it to my mechanic and he replaced the slave and master cylinder... So i went to pick it up today and we tried to move it to make sure everything works and the pedal feels the same so we tried to re-bleed it and we get pressure for about 20 seconds and then it all goes away!? im not sure why its doing this any help would be greatly appreciated.
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
Do you need to adjust the pedal height? After my manual swap we bled the lines like 3 times and still didnt have a pedal, then come to find out it was because the pedal was adjusted too high. Try looking into that...
Could it be a throwout bearing problem? Nows when someone else can chime in...
Adam_11
Car: 91 240sx
i'll havta try that today thanks.
