Clutch problems , please help
Krylonking
after bleeding the clutch system correctly more than four times , we have had the same problem -when we turn on the car - push the clutch peadat to the floor and try to shift it wont shift into gear, pressure plate is good and from the looks of things it just looks like the slave cylinder just isnt pushing out far enough, about 1/2 inch to1 inch short of dissengaging the clutch, ive tried the adjustments under the dash as well, any more ideas are welcome- please ! oh yeah- i did get rid of the bleeder box
goofynick6
Car: 1995 S14.5 RB20DET
Did you change the pilot bushing? and if so, is it the manual bushing? What clutch/bushing/t.o. bearing did you use? etc.
Nick
Krylonking
I didnt replace anything , everything was fairly new that came witht the motor set , there was already an aftermarket clutch installed , and it had alot of meat left on it , so i left it be
accel junky
What slave are u using?
Krylonking
nevermind , i got the clutch to disengage , i had to beat on it with a hammer . i guess it was just seized up , i got to take my rb20 down the road for the first time tonight , as soon as it hit boost it blew off the intercooler piping , it runs good but its running a little ritch , ill get that worked out tommorow , oh yeah ,also i was running with no power steering ,that was a ***** to drive , with the 90 , all i need to get is the resiviore from a 91 and up for it to work right?
JonPowell
Car: Cars, Music, My family
Mix & match between the Skyline and 240SX stuff, you dont really need to buy anything....
