moulton712 wrote:Don't do ACT, they are garbage. have had problems with them. the center splines tend to strip out.
If you had the splines strip out, there has to be a reason for it. For instance engine misalignment will cause the splines to strip out in a very short amount of time. I have no idea if that was the problem but to go on here and say ACT is garbage is ignorant, especially considering their track record.
I don't know which ACT clutch you had, but if it was a solid center then the splines will tend to wear since there is no torsional dampening as with any other brand solid center. The hardness of the ACT hubs are the same as pretty much any of the other clutches. Sure, the splines can be made harder, but then the input shaft wears instead which is not a good alternative.
