mikesudds »
https://forums.nicoclub.com/mikesudds-u8618.html
Sat Mar 26, 2005 3:01 pm
alright guys.i have a 92 240sx with an ACT 6 puck clutch in iti properly broke the clutch in.here's the dealit's been in the car for about 1000 miles now, and up until now it's acted fine
when i first got the clutch installed, the pedal would "grab" right on the floor.as i gradually drove the car, the pedal would start to grab a little further up on the pedal,
now, when i first start the car, the clutch acts fine. it doesn't slip or anything. but the longer i drive the car in one sitting, ie. 20miles or so,the clutch will slip horribly. i mean to the point that i can't even get the clutch to engage AT ALL.if you let the car cool down a little bit, it will start to engage again, just a little. so i was figuring it was the front main bearing was bad. so i pulled the transmission expecting to see oil all over the clutch disc. but there's no oil there at all. the casing is clean, just some residue.there is a little oil leaking from where the shifter goes into the transmission, but i was guessing that i possibly overfilled the transmission.
also the flywheel is fine. no burn marks on it or anything.the pilot and throwout bearing we're also replaced with the clutch.
thanks guys for the help.
