clutch problems (HELP ME PLEASE)
jasonrps13jdmdrift
Car: 1990 240sx
I have a 1990 ka24e 240sx and i just put my 4th clutch in june i dont think that the car should be doing this........... but every time i replace the clutch it is the same problem... the throwout bearing ......... its just a replacement deal from advance auto but it shouldnt go out like that and the last one i took out was cut open on the flywheel side..... plus now its broke down because the seal in the slave cylinder went out and siezed up the clutch fork ....no worries i may be a newbie but i wasnt dumb enough to take it out of gear.... please give me any info you can
float_6969
I'm going to move this to a forum that will be able to help you a little better than this one.
NISTECH
Check your free play on your clutch pedal. May be applying enough to drag the T/O
