clutch problemm! help..!!
oinkman
Car: s13
when i turn on my car the clutch feels as if its not working i have to push it all the way in and it feels soft
i have to pump it like 10 times before it can catch a gear. IT WILL NOT GRAB THE GEAR WITHOUT DOING THAT..
ive tried to force it in gear alittle once and heard some grinding noisee
what can it be.??
wat can i do about it.??
please helppp.!!!!!
also i was on the freeway bout 7 miles away from my house going about 60mph on 5th gear as i started to see some light smoke alittle less smoke then a lit cigarette barley noticable but was there=[
thanks, NICO
EnjoiNismo
Car: 93 240sx
Do you have brake fluid in your clutch master cylinder?
oinkman
Car: s13
blah-.- noo thought it was full but its not its empty.....
wat exactly should i feeeel it up with.?? anything specific.??
i should prob loook for a leak huh.? or is it normall.??
thanks
EnjoiNismo
Car: 93 240sx
Dot-3 Brake fluid.
Check your clutch master cylinder and the slave located at the bottom of the transmission.
It could be a slow leak, refill and go drive and check. This will give you time to save? lol
The Clutch master cylinder is only like 20bucks at autozone.
S13_RB25
Car: A 240 but no RB yet!
oh and since you have a s13, if you have a aftermarket clutch, remove the damper box. Its supposed to take the pressure of the clutch system but it really doesn't help us.
ag240
Car: 1993 Hatch, 1989 Hatch SE, 2010 Fronty SE
Remove Dampener Box, Adjust Clutch Pedal, Fill Clutch Master Cylinder, Bleed Line.
