Clutch problem
Omez
Car: Nissan 300ZX TT 91
Hi,
I was about to take out the car from storage when I noticed the clutchpedal had no pressure.
If I try to pump it while the car is running it is absolutely no resistanse in the pedal. If the engine is off I can build up a very small pressure if I pump the pedal fast.
I thought first it was a air problem, atleast what it felt like. But when I bled the system, only fluids came out.
Can it be that it is a large airpocket that hadnt come to the bleed points?
I also checked the master and slave sylinders without seeing anything wrong and checked the fluid level.
Any tips what I should check? or bring with me.
Im going out there again tonight and would appriciate any tips so that I dont drive out there for nothing. (an hour each way >.<)
Milton'Z Nissan'Z
Car: 1990 300ZX tt
1990 240SX
Most likely the master cylinder is gone. But check if there is any fluid leaking out of the slave when you pull the rubber dust boot off the end?
Omez
I checked yesterday and I couldnt see any fluid leaking.
Tho I was alone so I couldnt press the clutch while checking.
It was wet at the lowest point under the clutch, but seemed to be only water (for what I gather this is normal)
Is there a failsafe way to check the master sylinder or should I just replace it with an OEM or some other manufacturer to be safe the first time ?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
did you belld at the niple ont he passanger fender? if not there si likely a hoge air pocket somewhere in between, if nto It could be a bad master, the fluid will just pass by the seal and back to the resivior, but it's recomended to replace the clutch and slave as a pair
Omez
I bled both places. I'll head out in a few mins to try again.
Hope I will get the car out today :)
It has been a looong and cold winter.
