clutch problem?
180sx2fast4u
Car: 1991 240sx
I have a 91 240 with an sr20 and im having problems with my clutch. The clutch engages at a different spot thoughout the day and evently the pedal sits on the floor and i have to constantly pull the pedal back. When i pull the pedal back, the clutch doesnt enagage till the last sec. I am not losing clutch fluid and it has been bled. Any ideas
Hijacker
Car: '92 240sx Convertible
'94 F-150
Sounds like air to me. Make sure you have bled the master cylinder properly
Emperor_Tha
run steel line and bypass the damper.
180sx2fast4u
Car: 1991 240sx
damper already removed
180sx2fast4u
Car: 1991 240sx
I know someone has had this prob before. More ideas please
180sx2fast4u
Car: 1991 240sx
bump
david200095367
Car: 91 fastback 93 coupe w/s14 sr20det 98 s14 kouki
i had the same problem. it must be your master clutch cylinder. it's some how leaking air thru a bad seal or something. It doesnt mean if your not leaking fluid you dont have air leak. try that out and let us know.
180sx2fast4u
Car: 1991 240sx
thank you, workin on the car sat. i will let u know
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
david200095367 wrote:i had the same problem. it must be your master clutch cylinder. it's some how leaking air thru a bad seal or something. It doesnt mean if your not leaking fluid you dont have air leak. try that out and let us know.
