srpowered240sx »
https://forums.nicoclub.com/srpowered240sx-u30143.html
Fri Aug 24, 2007 6:32 am
if you can hear it well outside the car, i would suggest that its the where the clutch fork pivots. get under there and spray some wd40 on the pivot point (make sure not to spray much inside the casing, just in case it trys to find its way to your clutch disc, kindof far from it, but dont chance it). if you are confused, your slave cyl pushes one side of it, pivoting the other side of the fork inside the transmission, depressing throw out.
