Soravia »
https://forums.nicoclub.com/soravia-u34591.html
Sat Mar 17, 2007 9:55 am
I have the same issue. Stock spec clutch kit and throwout bearing. The clutch can be pushed in with hand tools but the slave won't push it in far enough. I've tried bleeding many times with help but it gets only a very small amount of pressure on pedal, about 4 inches raised from the floor. Both master and slaved are cleaned and checked to perform right. The boot on the slave is also clean and tied down well.I still can't make the slave push the clutch in. Should I bypass the joint where line from master goes and a line comes back to slave?
Thanks
Modified by Soravia at 5:07 PM 3/17/2007
