gehzumteufel wrote:but it is ONLY in the morning. no other times. can it still be that?
have you tried adjusting your clutch master cylinder?
Im in the process of replacing my clutch mines was doing the same thing, thought it was the clutch slipping, after i took it apart the clutch was still in good condition still had more beef with that much beef atleast it shouldn`t be slipping but since i have it apart now i`m going to go ahead and replace it, i don`t know forsure if its my clutch master cylinder that caused this my guess it might of need adjusting, but i was having the same prolem your having, last thing i did was change the clutch master cylinder this was 2or3 weeks ago before all this happened, hopefully after i put everything back together i`ll see how things go.
