240sxOwner wrote:yes i have used that to adjust the clutch engagement.
When i say the clutch is adjusting itself i mean that when i start driving the clutch has play and is relatively soft.....after driving for 5-10 minutes...the pedal has no play at the top and it hard as a brick.
Yeah sounds like air. Kinda like if there is air in your brake lines, if you pump them it will eventually build pressure.
I just ordered the SS clutch line from SPL and a speed bleeder. Total of $27. The line is supposed to bypass the damper where alot of air gets trapped.
