Clutch Problem
theShadow
Car: 1992 240sx
Having some problems with my clutch system. The clutch pedal falls to the floor with almost no effort at all. There feels like there is no pressure in the lines, and it dosen't even kick back. It just falls to the floor and stays there. The master cylinder fluid resevoir is full of clutch fluid, and we tried to bleed the lines, with no success. Only a tiny bit of fluid was draining out of the slave cylinder lines. Has anyone experienced this problem before or have any idea how i can fix it?
Iamjohnhayes
Car: 89 Single Cam Hatch
i had a similar problem. my clutch master cylinder was shot it was letting air into the system when ever i pushed down the pedal. if i bled the clutch it was good for maybe 2 shifts. However i didn't have any problem with the slave or with bleeding the clutch.
