clutch problem
chamorro
i just replaced the clutch on my 95 240. i replaced the t/o bearing, pilot bushing, resurfaced the flywheel new pressure plate and disk. i ut everything back in and my clutch doesnt feel the same. the clutch is a whole lot softer than what it was before i put it in. the car still drives though. I then bled the clutch and no change. so i figured it might be the slave cylinder, so i replaced that and bled it again. no difference.
please help. this is my daily driver and i cant afford another car.
thanks in advance,chris
NISTECH
Welcome to NICO Chris.
What kind of clutch kit did you get? I have experianced the key value nissan clutch kits being inhearently softer then the original factory clutch due to a softer pressure plate spring. Is it possible thats what your feeling? If it is not then did you properly torque the pressure plate down?
chamorro
the clutch is from autozone, i think the manufacturer is FENCO. I dont think the pressure plate is the prob. i was wondering if t master cylinder might be the problem.
NISTECH
You say you didnt have the problem prior to doing the job, The master cyl was there prior and you did nothing to it, I am thinking the problem is directly related to the parts you installed or the installation process itself.
