centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Fri Jul 22, 2016 11:44 am
Well, I got mine going last night. The FSM direction was good. The only bleeder valve I messed with is the one on the slave cylinder. I ended up flushing out all of my old fluid. I'd pump the pedal by hand about 5 times, then put my skateboard between the pedal and seat to hold the pedal down. I go under the car and bleed the valve. Then repeat. After each bleed, you have to lift the pedal up again. The first couple of times there was no pressure, no need for the skateboard, and almost no fluid coming out when bleeding. The pressure built up though and eventually I was pumping with my foot, holding it down with the skateboard, then bleeding until the bubbles were all gone. Then I adjusted my pedal and bled it a couple more times. Did you ever get yours going?
