fleabay »
https://forums.nicoclub.com/fleabay-u145403.html
Thu Oct 15, 2009 1:57 am
I have a problem with my 720 pickup (stick shift). I have no response from the clutch. I can change through the gears when vehicle is turned off but not once running. If I put it into first gear then try starting - with clutch depressed - the vehicle lurches forward because depressing clutch doesn't put it into neutral. I really don't know if the clutch pedal 'feels' normal or not because I haven't driven this vehicle much. There is some pressure I guess but it does feel pretty light.
I noticed a fluid leak on the firewall behind the clutch pedal. The leak was traced back to the clutch master cylinder which I have now replaced. I have bled the system but still I have no response from the clutch.
I have checked the slave but no sign of leaks there.
How can I tell if I have bled the system properly? Is there any way of knowing or do I just asume the problem is in the clutch housing or maybe the transmission itself?
