Clutch Problem, need advice
SrS13
Car: 1990 Fastback, 1993 Convertible Coupe
Ive been having this weird problem for some time now maybe one of you guys can help me out here:
Sometimes Ill bee fully engaging the clutch and any gear wont go in I have to release the clutch then depress it again to get the gear in. Other times Ill be at a stop clutch engaged gear in and the car will start moving forward.
Any ideas??
Thanks
StrangeLove
Car: 1995 Nissan 240sx
Quote »Other times Ill be at a stop clutch engaged gear in and the car will start moving forward.[/quote]
Seems to me that the clutch is not fully disengaging from the flywheel... I'd get this checked out right away... Unless you want to buy a new clutch :D
I might be wrong though...
navysnail
the slave cylinder on the side of the transmission is probobly leaking. my friends did this too, your having to pump it up to build enough pressure. look around and see if it is leaking.oh ya, its on the passanger side.
navysnail
or the clutch master cylinder, check that too
