Clutch problem: Help with diagnosis?
wishihadas14
Car: '93 240sx Coupe
1993 Nissan 240sx KA24DE 5-speed
Yesterday, when I was pulling into a parking lot, my clutch gave out. Not out as in the clutch disk is bad, but as in the pedal doesn't cause the desired effect. If the clutch was bad, it wouldn't matter what gear I was in, the car wouldn't move, but this is the opposite. When the car is off and nothing is spinning, I can put the car in any gear, but the pedal does not disengage the clutch from the flywheel so when the car is on the car will stall in any gear, even with the clutch pedal all the way to the floor, though it is a little better with the pedal in. Clutch slave cylinder bad? There are no leaks in the lines and the system is bled properly, fluid is filled. Pivot fork moves a little by hand but only in the direction the slave cylinder would push it, not in and out of the trans case or side to side in its hole. I will gladly answer any questions you might have if you would please help me get this fixed. Clutch is a SPEC with <6000 miles on it, flywheel is a Fidenza same mileage. The only 2 things I can come up with is the slave cylinder or the release fork pivot (broke due to the strength of the clutch????)..... Please help me, I'm without car for now.
MaximA32
Do you notice any fluid leaking from under the car?
wishihadas14
There are no leaks of any kind, and i ran over all the lines. No fluid under car, no leak from either cylinder that I can tell. I'm really curious about the symptoms. What would it be like if my pivot arm was broken? Is this really just a failure of one or both of the cylinders due to the much stronger clutch?
automech
Car: BMW 328
It was either the master cylinder,or the clutch plate.If there was a horrible smell than it was your clutch disc. Any time you get clutch or transmission work done it's expensive. But I think in your car model, its not that pricey.
wishihadas14
Well, i have come to the conclusion that its not any of the hydraulic components, the slave pushes the fork back all the way so it has to be something internal. I think it must be the pivot point broke, my fork bent or somethings up with the retainer spring. I don't see how it could be anything with the disc or plate since they're SPEC stage 5+ and I'm not even boosted yet and the clutch kit has less than 6000 miles on it. Help?
redsx13
Car: 93 240sx 03 350z
i had a very similar problem. my clutch fork had bent and was longer functioning as it should.
