clutch pressure prob -- please help
tetsuo
Ok, my clutch pedal loses most of the pressure (so I can't shift gears) after about 30 minutes of driving (actually now only about 10 minutes, getting worse!). I have to pump the clutch several times rapidly and then it builds up again. Well I know there's air in there but help me tackle this one.
The strange thing is I just got done replacing the master AND the slave clyinders.
The bolts that I have changed are all secured, there are no leaks (that I can see), and the fluid level doesn't seem to be changing.
I believe I bled it correctly, I bled it twice and both times it ran fine (with full pressure) for several days... and then the problem comes back. Unless... I missed some air in there and they crept back after those days ??
I'm at a real loss here. Trying to solve it, I'm wondering:
1) what exactly is pumping the clutch do? Does it alleviate air in the system?if not, how does it build back pressure?
2) I'm wondering if it losses pressure a lot quicker on the freeway(because it feels that way). Does a clutch that's engaged change the state of the fluid system?
Thanks in advance!
180fan
Car: 89 fastback
you've got air bubbles. bleed it properly and the bubbles will go away.
SeanC
Car: 1993 240sx SE
did you properly bench bleed the master? sounds like thats your problem.
