Clutch Pressure Fluctuation
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
supra_rulz
Car: Toyota Supra MK3 1JZ
Datsun 720
just recently the clutch has lost all pressure when i push it in. cant start the car in 1st gear with the clutch pressed in. the weird thing is once i start the car (in neutral) and wait a min or so, its ok. but the engagement point is literally .25 inches off the floor. drive it for a few more min's, and it starts to go back to the "original spot" which is still lower than what it used to be. what could be causing this? Thanks
supra_rulz
Datsun 720
anyone?
synack7350
Car: nissan '83 720 king cab pickup 2wd 2.4L Z24
not positive but thinking cluth master cylinder. I'd of course rule out fluid related issues first.
supra_rulz
Datsun 720
alright, so checked the fluid, was none, so added. still nada, found a leak in the clutch fork pusher-thing. (very technical, i know) so off to fix that tomorrow
synack7350
yep that'd prolly do it. like brakes leaks introduce air into the system. Air compresses where fluid wont. Naturally this causes all sorts of bad things to happen.
supra_rulz
Datsun 720
alright, so i replaced the master and slave after lots of swearing and driving back and forth to o'reilly's. bled the system and still couldnt get pressure. its down to zero movement now. what am i doing wrong?
synack7350
you have fluid in the manual transmission case right? beyond fluid related issues I have no idea. When a clutch fails usually there is a lot of smoke involved so it doesn't sound to me like the clutch itself is bad. It still sounds like fluid too me.
supra_rulz
Datsun 720
so it turns out, i didnt know how to properly bleed the system. therefore, TONS of air inside every possible inch of the line. borrowed one of those vacuum thingy's and now everything works.
synack7350
glad you got it sorted.
Return to “Datsun 720”
