Keachj06 »
https://forums.nicoclub.com/keachj06-u82400.html
Thu Feb 28, 2008 8:57 pm
ok bled the system adjusted the rod and now the clutch is starting to slip under high torque, what could it be this is horrible the clutch disc, flywheel, and pressure plate only have 3k miles at most on them and i replaced the clutch pivot ball , fork, t.obearing,pilot bearing, and t.o bearing sleeve when i did the clutch change. also how do i go about checking all the reservoirs to clean them from all the gunk if that is even the problem is the brake booster the reservoir in between the smaller reservoir where the clutch is and the motor sorry if this sounds lame iam kinda new to these cars.
