Clutch Pedal wires and some
thepitt
Car: 1990 240sx
These wires are coming from the clutch pedal itself, from a switch. Im doing a 5 speed swap with my sr and was wondering where these go. I looked in the FMS and saw the they go into an inhibitor i think. is this necessary? The wires are blue w/ white stripe and a black one. When i was trying to crank over my motor it would start on its own without me haveing the key in nor the clutch pedal pressed in. I would just plug battery terminals in and it was trying to crank but no fuel pump. Then I fixed the fuel pump and now it wont crank at all. Could have something shorted out cause of it trying to start on its own.
Hijacker
Car: '92 240sx Convertible
'94 F-150
that switch is part of the "car can't start with the clutch not disengaged" system. On auto cars, that's the park/neutral switch which you more than likely jumpered. I usually plug the clutch switch in anyways just to make everything tidy looking, but you don't have to worry about that wire.
