You're right about it changing the engagement point. More play will cause it to engage lower. Less play will cause it to engage higher up(because the release bearing gets pushed into the pressure plate sooner). Just watch and make sure it engages completely before your foot is off the pedal. I personally like it to engage closer to the middle, so I gave it slightly more play than normal. gjget_up_mark wrote:ok this is exactly what i did. i turned the rod all the way till it got hard to turn and i noticed my pedal had no play at all so i backed it out liek a turn and a half and it seems to have a tiny hair of play like you said. however my clutch engagement point is further up now but i like it. tell me if this adjustment can effect clutch engagement points. i like it were its at i can shift quicker now and my car will chirp 3rd with my spec 2 cluch on a stock ka.
