S13FASTBACKSR wrote:it still seems like it has air in it? are you sure its bled fully? also do you know that vaccuum box that everybody removes? if you havent removed that go ahead and remove it..your T.O. bearing if bad will make a grinding type of noise when engaging..there is an adjustment on the pedal to adjust the height but if it is not coming up due to air in the line than thats not it..if its just not coming up high enough but there is no air then play with that
of course i removed that dreaded dampning box, and when i engage that clutch it sqeaks at the transmission if that means anything. oh and also when im driving when i hit the clutch i heard somthin grinding in teh transmission sometimes maybe its teh to bearing
Modified by goj_cloud at 8:04 PM 4/14/2007
