Is this what you are trying to say?
distriniboy2002 wrote:Ever since I replaced throw out bearing, I noticed that my clutch does not remain soft. Instead, it gets soft through bleeding the slave cylinder, then it gradually gets stiff...so stiff that the piston from the slave cylinder does move at all on throw out bearing plate unless you bleed, and it gradually gets stiff, so stiff that when you put transmission in gear the car does move when in 1st gear. Sometimes when guning it, the damn clutch just slips. Someone please help
[email protected]
Did you just replace the throw out bearing, or the entire clutch? Did you bleed the master cylinder as well? Did you make sure there was nothing binding on the input shaft or on the clutch itself?
Might be time to replace the slave and master cylinders.
