Clutch pedal sticks
bmaze35
Car: 05 G35 coupe
New,to the group help,, not sure if I am in right section ,,, but My clutch pedal on and 05g35, started sticking on the return from a shift right at the shift point , no problem shifting , I bought the car new , dealer said I need a new clutch, 1,200 bucks ouch
joe603
Car: 2014 Durango R/T
Welcome to NICO!
Do a search...this has been discussed. It's just the way our clutch is designed.
Now I say that if your clutch pedal sticks to the floor when you try and do a high RPM take-off (say over 5k). This is normal for the OEM clutch...not sure if it's a "safety feature" or a flaw in the design. An aftermarket clutch will fix it. However, aftermarket clutches will rattle more than OEM.
Hope this helps.
bmaze35
Car: 05 G35 coupe
thanks yes , it helps, I did search couldn't find anything I will try again
G_whizz
Car: 2010 G37 Coupe Sport
LOL.. wow you been MIA??
It's totally normal. Try what Joe suggested, if your in neutral and you rev to 5kRPM and pop it and it sticks...then don't worry about it. It's a safety feature. So go tell your dealer to stop trying to rip you off and he should go back to mechanic school.
bmaze35
Car: 05 G35 coupe
Thank I will try it , Thanks
